Thread: Lay - Z Spa heater . No pump / E02 error
    Hi,
    I have a Lay-Z spa from 2012. It's the platinum/vegas version with the heater that can only heat or bubble, not both at the same time.
    The pump worked for just over a year, only need occasional cleans, but it's now in a state where whilst the BUBBLES work fine, the pump itself won't pump around water to filter.
    After power on, if the filter/heater setting is selected I get a few seconds of silence then beeps with E02 displayed
    E02 seems to be a water flow issue.
    I tried backflushing - in fact I can squirt water through either way around, and it comes out the other end just fine (in->out or out->in)
    At no point is there ANY noise.
    This suggests to me that the pump has failed/has bad connection
    If it was the flow meter I suspect it would pump for a while then stop.
    I've dismantled the unit but it's not clear what to check. The large "pump" unit seems clear of debris -- but thinking about it now perhaps this is just the air blower
    Where is the pump in this unit?
    Any recomendations on getting a spare part?
    I feel a little guilty posting about this cheap temporary unit here. One day I'll invest in a proper spa.... this one I acquired from someone who no longer wanted it!
    many thanks
    Nigel.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Lay - Z Spa heater . No pump / E02 error
    Bumping post to add it to today's activity stream. Hopefully someone will have suggestions for you.
    Love TFP? Become a
    TFP Supporter!
