Thread: Stingl Switch Issue - PLEASE HELP
    My Hayward Super pump burned up yesterday, and I replace it with a newer Super Pump, and now the Stingl Safety Switch doesn't work properly. When I turned the breaker back on the pump immediately fired up, and the switch wouldn't control the pump. The Switch says the system is off but the pump stays running. Off button will not stop it. Any ideas what could cause this? Didnt change any wiring config.
    20,000 gallon 18x36 Fiberglass with toe kick and sloping walls in deep end
    Sand Filter with Hayward Super Pump
    Raypack Gas Heater
    Re: Stingl Switch Issue - PLEASE HELP
    One way or another, some of the wiring must have changed.
    Perhaps if you posted some photos of the wiring we might be able to evaluate what happened.
    Will try for you. Thanks
    Raypack Gas Heater
