Results 1 to 9 of 9
Thread: 18 Month Anniversary,
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Cool 18 Month Anniversary,
    Wow, I just passed my 18th month of being a member on TFP. I cannot thank all the regular contributors enough for all I have learned on this site. At 18 months I have never once had to slam my pool except at opening which was done by my pool builder. I have NEVER registered CC above 0. Pretty amazing considering the money pit that was my old pool at this same home nearly a decade ago. Of course that was before TFP and the empowerment that comes with knowledge. At first I checked my chemistry almost daily. You all were correct in that after I "learned" my pool I would not have to test as often. Now I don't even measure MA when I add it. CYA is not measured before adding but is done gradually, which I am doing now. I cannot believe how easy this is. My total chem. costs after 18 months is under $200.00. My tests today are as follows:
    Salt 3300
    PH 7.5
    OTO CL 5
    CYA 50
    FAS/DPD CL 5
    CC 0
    TA 70
    CH 260
    On top of that I have had to clean my filter just once about a year ago and right now I am only 1psi above clean. All this is because of all the knowledge I have gained here so Thank You All for teaching me!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Casey's Avatar
    SW PA
    10,444
    Re: 18 Month Anniversary,
    Beautiful pool and back yard!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Divin Dave,
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Happy TFP-iversery!
    Love TFP? Become a
    TFP Supporter!
    Oct 2012
    604
    I like that Zea3, TFP-iversary!
    Thanks Casey.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Fantastic! Love the decking.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Smykowski's Avatar
    Sep 2011
    3,065
    Great post, and great stats.
    This one is my favorite, though:
    Quote Originally Posted by ComputerGuyInNOLA View Post
    Butterfly's Avatar
    South Carolina
    10,045
    Congratulations! We may have helped, but you did all the work!
    yeah, we love the TFPC system, too
    You're done SLAMing when:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    How many things do you come across in life that are cheaper, easier and work better than the traditional method?
