Green pool posting numbers
May 17, 2010
115
Opened to green pool.have swg 25,000 gallons vinyl .
FC 0
PH 7.8
TA 50
CYA 10?
Salt 2700
Can't get pool calculator to work??
What should I add first ? Please assist with order?
If I add stabilizer can I back wash? How much
to add. How much concentrated bleach to add. Thanks
PoolMath(link above) should work for you.
In order of importance:
FC -- get some bleach in there asap PoolMath tells me 225oz of 8.25% this should get you to 6 FC
pH -- 20 oz 31.45% MA This should get you pH 7.5
CYA -- 83 oz of dry Place half of this in an old sock and hang it by the running return. do not add the rest yet! The full dose would get you to 35, but do it in stages
Let these additions settle for a day with the pump running.
So I'm getting it clear. Had issue with floating sides with rain. Been repaired and refilled after lowering half way. New numbers. Please advise how to fix PH and TA
FC 14.5
PH 6.8
TA 50
CH 50
CYA 30
SWIG not on yet. Almost clear still need vacuum rest of algae out. Thanks
