Results 1 to 16 of 16
Thread: Green pool posting numbers
    Opened to green pool.have swg 25,000 gallons vinyl .
    FC 0
    PH 7.8
    TA 50
    CYA 10?
    Salt 2700
    Can't get pool calculator to work??
    What should I add first ? Please assist with order?
    If I add stabilizer can I back wash? How much
    to add. How much concentrated bleach to add. Thanks
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Green pool posting numbers
    PoolMath(link above) should work for you.
    In order of importance:
    FC -- get some bleach in there asap PoolMath tells me 225oz of 8.25% this should get you to 6 FC
    pH -- 20 oz 31.45% MA This should get you pH 7.5
    CYA -- 83 oz of dry Place half of this in an old sock and hang it by the running return. do not add the rest yet! The full dose would get you to 35, but do it in stages
    Let these additions settle for a day with the pump running.
    Thanks got it going. Can I back wash to waste should I set to filter?
    Central, VA
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ok, one question, how did you get the 10 for your CYA reading the view tube that comes with the TF-100 only goes down to 20?
    At 20 I could still see a faint image fill up top of tube. Never really got it up past 20-40 last season
    Central, VA
    Now PH is 7.2 do I need to raise it now?
    Central, VA
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    No your PH is fine now.
    Jeff
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    With an SWG, pH will climb on it's own. Just monitor it and bring it down when it reaches 7.6-7.8
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You are planning to SLAM the pool ? http://www.troublefreepool.com/conte...tain-shockingl
    Jeff
    Yes I'm going to SLAM it. Thanks for help!3
    Central, VA
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Just make sure to turn the SWG off while your SLAMing. No need to run it for the SLAM process.
    Jeff
    Ok I didn't know that. Thanks
    Central, VA
    So I'm getting it clear. Had issue with floating sides with rain. Been repaired and refilled after lowering half way. New numbers. Please advise how to fix PH and TA
    FC 14.5
    PH 6.8
    TA 50
    CH 50
    CYA 30
    SWIG not on yet. Almost clear still need vacuum rest of algae out. Thanks
    Central, VA
    Smykowski's Avatar
    Sep 2011
    3,065
    FC must be below 10 in order for your pH test to be valid. I would let FC drop to 9 or so, and retest pH. Bring pH to 7.2, raise TA, to 70, then continue with the SLAM.
    30,415
    read "The ABC's of Pool Water Chemistry" up in Pool School
    Thank you for the information. I'll wait for the FC to fall then make my adjustments. I'll also will raise my CYA to keep my numbers in line for the SWIG.
    Central, VA
