Results 1 to 8 of 8
Thread: New pool owner- pump basket leaks on low speed?h
    Feb 2014
    Boston suburb
    11
    Hi everyone,
    First off, many thanks to the wealth of information that has been collected and shared on this site. I'm a new pool owner, and have learned a lot already.
    I just had my 21' above ground pool installed this past Tuesday. The pool installer had to come back out because of some leaks I found from the pump and skimmer box, which he fixed. Now, however, my 2 speed hayward pump leaks from the basket lid, but only on low speed? I primed the pump... There is a quarter size air bubble in the basket.
    Why would the basket only leak on low speed? I've read about luring the gasket for a Better seal. Is this something I may have to do even for new equipment?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: New pool owner- pump basket leaks on low speed?h
    Glad you're here!
    When the pump is on high, are all the bubbles gone?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Is the pump basket leaking water out or air in? On low speed, an AG pump below water level would most likely have positive pressure in the pump basket so that is why I ask.
    Mark
    Feb 2014
    Boston suburb
    11
    Quote Originally Posted by Smykowski View Post
    Glad you're here!
    On low speed, the bubbles collect into one larger bubble. On high speed, the larger bubble is broken up into smaller bubbles, but they are not completely gone.
    Quote Originally Posted by mas985 View Post
    On low speed, it is definitely leaking water out. But wouldn't it also leak out on high speed as well?
    Just guessing, but: On high speed the suction is probably strong enough to pull the lid down against the seal and cause it to seal properly. On low speed there is either less suction, or none, and the lid is not held on so tightly, allowing any play in the lid closing system to result in a leak.
    Feb 2014
    Boston suburb
    11
    Ahhh.... this makes sense. Is it normal to have to lube the basket gasket for a new pump?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It wouldn't hurt anything to give it a little lube !
    Jeff
    Feb 2014
    Boston suburb
    11
    I should add.. the pool installer said it was normal for a few leaks since the temp here has had such big swings. I didn't buy it, which is why I posted.
    I'll pick up some lube today!
