Results 1 to 18 of 18
Thread: Leaking Sand Filter
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Leaking Sand Filter
    I noticed water pooling around the bottom of my Sand Filter. The sides of the filter are dry, with no obvious leaking from above, and the pump is dry. I have attached a pic of the filter with the damp area around the bottom of it. I won't get the pooling water until I turn the pump on. Any suggestions as to where the water may be coming from? Is there some sort of "plug" in the bottom of the filter?
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Leaking Sand Filter
    Have you checked the drain plug ? Start your pump and see if it's coming from there.
    Jeff
    Smykowski's Avatar
    Sep 2011
    3,065
    Like Jeff said, look for the black cap at the bottom of the filter body. I can't see it in the photo, so it must be on the other side.
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    The drain plug is tight and dry
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I take it you drained it over the winter correct ?
    Jeff
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Absolutely
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,629
    Haven't overlooked rainwater, dew, sprinklers?
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    No - pad stays dry until I turn the pump on. Never had this issue before. Water will pool around the filter and eventually, around the pump.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Check the plug again while the pump is running and make sure it is not seeping under pressure. Also check the plumbing around the pump and filter.
    Love TFP? Become a
    TFP Supporter!
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    I have checked everything. Nothing leaking from around the top of the filter, pump is dry. Plug is dry. I was gone today for 5 hrs - I have attached pic of the water that has leaked during my absence. Pump is on a timer, so it turned on by itself - no standing water around the base of the filter when I left.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Unless there is small crack in the bottom I'm out of ideas.
    Jeff
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    That is what I have worrying about these past two days. Don't know how or why, but it is starting to make sense. I have no way of checking it out.....will have to call pool man. If it is a crack, I wonder if I could try spraying that "rubber sealer" stuff on it out of a can?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Leaking Sand Filter
    I don't think that spay rubber seal stuff is an option if there is a crack.
    Is there anyway you can disconnect it and take a look at it yourself ?
    Jeff
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Wouldn't have any idea how to go about it. I can do simple things, but have never disconnected any of the plumbing.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Leaking Sand Filter
    If you could post a pic of the plumbing to see if you have unions in place, we could help ya. If your not comfortable with it have somebody do it. Your call.
    Jeff
    Jul 2009
    Houston, Texas
    9,410
    If there is a crack at the bottom of the filter then pressure is causing it to open up when the pump is on. Over time the crack will get worse until it is either leaking constantly or experiences a major failure. If you can post pictures of the plumbing that will help us help you determine the next step.
    Love TFP? Become a
    TFP Supporter!
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Good news! MY son came over to pick up my granddaughters and he went out to the sand filter and literally laid down on his belly to look underneath. It was the drain plug after all. He said I would never see it standing up or kneeling. Even though I ran my fingers along the shaft of the plug, I did not feel the water. He said water was actually trickling down from out the bottom of the plug, running underneath the bottom of the filter and coming out from under the filter "stand", making it look like there was a possible crack in the bottom of the filter. While he was down there, he also found the round "gasket" from the drain plug laying in the gravel. He put the gasket in, screwed it back on and no more leak. I should have been more persistent. I can now smile as I won't be calling my $350.00 hr pool people. Thanks to all of your for your wonderful help. Without this website, I would not be enjoying my beautiful sparkling pool, nor would I be able to do the opening and closing by myself.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Leaking Sand Filter
    Good job. That's what I thought it was in the beginning. I couldn't understand what else it could be. I'm sure that makes ya feel a lot better 😎
    Jeff
