Thread: skimmer basket collar weir - skimmer sucking air
    Apr 2014
    Buckinghamshire, United Kingdom
    6
    We have a 28' x 14' inground pool; the skimmer has a circular basket that fits in it with a circular floating "collar" weir (Certikin HD105).
    Sometimes we're finding that the floating weir has risen so that water isn't making it over the weir and the skimmer is sucking air and the pump endlessly trying to prime. If I push the weir down - after a few attempts - it'll find the right level and start working OK again. Out of the water, the weir moves freely up and down so I'm not sure what's going on.
    This problem usually occurs on the days we found the skimmer basket floating - ie not correctly seated - when the pump came back on in the morning. It's like when the pump shut off the previous night the skimmer basket has floated up so that when the pump comes back on the water just bypasses the skimmer basket. Again, I can push it into place each time but I wonder if I need to weight it with something? A new chlorine tab seems to be enough to keep it in place. Not sure how to fix the weir problem though!
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    Re: skimmer basket collar weir - skimmer sucking air
    i think your water level is too high and as the floating skimmer raises it is allowing to kick slightly sideways
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Welcome!
    A rock makes a good weight. Just make sure it's too big to go down the suction pipe if it gets dropped somehow.
    Apr 2014
    6
    Thanks guys. I don't think the water level is too high... the problem occurs more frequently when the water level is lower (say 50% up the skimmer opening), and doesn't happen when the level is high enough (ie >75% up the skimmer opening) to be at the right level for the weir at its highest point.
    I think I'll try putting a rock in the basket, though - good tip!
