Thread: Spa Heater Question
    Apr 2014
    Austin, TX
    3
    Question Spa Heater Question
    Hi guys, I'd like to start off by saying I'm a complete pool newb... But this website has helped a TON on getting educated about our pool/spa!
    We just bought a home that came with a pool and spa with spill over waterfall. Pretty much 0 information about the pool/spa or equipment was provided to us when we bought the home. Heck, the previous owners were even claiming they did not know the pool capacity. In any case, I digress...
    We have some guests coming over in a little bit to take a dip in the spa so we decided to turn the heater on a few hours ago. We've noticed there's been very little change in spa temperature since the 3 hours we've had it on. It's gone from about 80 to 85 degrees since then. I guess what I'm asking is... Is the heater really only for "temperature control/maintenance"? Or is it intended to use as a hot tub?
    The heater we have is a Pentair MiniMax Pro 400. We've removed the side panel to check the heating elements, and they all appear to be working just fine. Thoughts?
    Jordan
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Spa Heater Question
    Welcome to TFP!
    Do you have 3 way valves on your pump and filter? There may be a way to isolate the spa from the pool for heating that only.
