Results 1 to 9 of 9
Thread: chlorine tablets now come in individual packets?
    Oct 2010
    michigan
    284
    I use tablets at start up to raise my CYA, i drain 1/3 of the water for winter closing.
    Just bought a bucket of 3 inch tricolor tablets. They are all individual wrapped, what a mess. 4-6 where broken, and many had powder dust. Then the hassle of opening it packet.
    preferred them unwrapped, but i guess they did that to reduce the super strong chlorine smell, but chlorine dust blowing every isn't much better.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Re: chlorine tablets now come in individual packets?
    Some manufacturers do that. I think that it's a bad idea. It's one of those ideas that might seem like a good idea in theory, but in the real world, it just doesn't work.
    Support the site
    38,475
    I know Leslie's does that ... so then you end up with powder flying every where while trying to open it and then all the wrappers with chlorine powder on them to deal with. Very annoying.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    I dunno... I needed a few pucks the last time I left town and I couldn't see buying another whole bucket. The local pool store had individually wrapped ones for sale.
    38,475
    Well that is fine. But why wrap every one in a bucket?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    ... a second chance to rethink using them?
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Quote Originally Posted by JesseWV View Post
    Kinda like having to make sure the safety is off before you pull the trigger!
    Mar 2007
    San Rafael, CA USA
    12,082
    I noticed that some manufacturers started individually wrapping the Trichlor tabs in a bucket, but I thought it was due to hazardous material regulations since that lets one become exempt from labeling, placarding, and shipping paper requirements by getting under the "limited quantity" exception. To do that, one must have an inner packaging of no more than 1 kg (2.2 pounds) net weight of hazardous chemical and an outer packaging of no more than 30 kg (66 pounds) gross weight. See 173.152(b)(1) Exceptions for Division 5.1 (oxidizers) and Division 5.2 (organic peroxides).
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I guess it could also limit humidity from coming in contact with every tablet each time you open the bucket. It should theoretically reduce the amount vapors that practically knock you out when you open the lid.
