Results 1 to 11 of 11
Thread: Weird white powdery substance in pool
    Apr 2014
    United States
    5
    I have an 18' above ground pool. We didn't put a cover over it this winter so it got full of leaves. I worked for several days, got all the leaves out, got the chemistry right, etc. but I noticed after scooping the leaves out, where I was dumping them, this white powder residue. I'm not sure what it is, but I believe its the reason I cant get my water clear.
    My chlorine is 2.5, PH is 7. I've only got a small test kit that test those two. I plan on getting a better one this weekend. Any thoughts on what this might be or how to clean my water up would be greatly appreciated.
    Here are some pics of the residue and of the water.
    Richard
    18' AG Dougboy 7000 Gallons, Hayward 1.5HP Power Flo Lx, Hayward C1200 Star Clear Plus filter, Pool Rover AG Cleaner.
    38,475
    Re: Weird white powdery substance in pool
    Welcome to TFP!!!
    Please be sure you are buying one of the Recommended Test Kits and not just what a store tries to sell you. It is very rare to find them locally.
    What kind of filter do you have?
    Please add your pool details to your signature and a better location to your profile as described HERE as it will help us help you.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Welcome to TFP!
    I can't tell you what that white residue is, without more information from you.
    If you go here, and see what info we need to help you, we can start to help you get your pool cleared.
    Honestly, you will not find a good enough kit at your local store. You really need to order the TF-100 from http://TFtestkits.net. don't think of this as an expense, think of it as an investment in getting and keeping your pool clean, clear, and safe for you and your family.
    In my signature, I show having the second best test kit, the Taylor K-2006. I order all my reagents from http://TFtestkits.net, as they are the same I would be buying from Taylor.
    Once we know more about your location, your equipment, and what you've been using in your pool, we can go from there.
    dag nab it Jason! I missed the mark again!!
    Apr 2014
    United States
    5
    Thanks, I've added the info to my signature and I'll take a look at those test kits.
    Richard
    38,475
    I was going to guess DE, but looks like you have a cartridge filter.
    Is your filter not capturing it? Have you vacuumed? How rapidly is your filter pressure rising?
    Apr 2014
    United States
    5
    I just ordered the Taylor K-2006.
    I've changed filters, cleaning in between. I've turned the pump off and let the water settle for 3 to 4 hours then I've vacuumed, I've done this about 3 or 4 times. But even when I turn the pump off for several hours, the water is still very cloudy.
    Richard
    38,475
    Could be algae in the water as well. Once you get your kit, test the water and post the results. Then follow the SLAM Process.
    BTW, if you do have to go through the SLAM process, you likely should order some more FAS-DPD reagent because the K-2006 does not come with enough like the TF-100 does. Everyone always falls for the cheaper test kit when in reality the TF-100 is the better deal.
    Apr 2014
    United States
    5
    Any idea on the white powdery substance, what it might be?
    Richard
    Salt, calcium or both are all obvious possibilities. A full set of test results would sure help narrow it down.
    Apr 2014
    United States
    5
    Well the kit is on order, so It will probably be next week before I can continue. I'll pick up a couple cases of liquid chlorine, need it anyways.
    Richard
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    While you are in an ordering mood, let me repeat what Jblizzle said: You will need more R-0870, and R-0871. The Taylor kit does NOT have enough of these. Also, the R-0013 is just not quite enough to do more than a few tests, so you might want to order that too. Trust me on that one. I bought my kit before I knew about the TF-100, or I would have gotten that, with the XL option and speedstir. Believe me, I kick myself every time I have to order replacement reagents........
