Thread: Water stick insect
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Water stick insect
    Just went for my first swim of the season. I just found two of these insects crawling around underwater on the pool wall. I looked it up and looks like what is called a water stick insect. Has anyone ever seen these before? Any treatment advisable?
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Water stick insect
    I'll bet it got your attention. I would first try maintaining FC at the high end of the recommended range, according to your pool's CYA. If that alone doesn't do the job of repelling these critters, you can add Borates up to 50 parts-per-million (ppm).
    Casey's Avatar
    SW PA
    10,450
    Ummmm.... Ewwwwwwww!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Yeah. Eww. Maybe save a few to scare people out of the pool.
    Isolated Spa - 345 Gallons
    I think they look neat! If they don't bite, would leave them so I could enjoy watching them move around and my daughter could get creeped out.
    Chris
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    Oct 2012
    604
    Chris, they do look neat. I have been doing some research. They are not dangerous despite having the nickname Water Scorpion. When you fish them out with the net they play dead. I did not harm them, just put them in the grass. From what I have read a lot of people catch them and keep them in aquariums.
