Thread: Pentair MasterTemp Release Valve?
    Split by moderator. Please start a new thread for your own questions. Thanks, jblizzle
    This is a little off subject, but just had a Pentair MasterTemp NG 250HD installed. PB did not install a high pressure release valve on the unit, is this something that definitely is required, or just highly recommended? Thoughts?
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Re: Pentair MasterTemp Release Valve?
    Per the manual, "Canadian code requires and some U.S. local codes may require installation of a pressure relief valve (PRV). " So if it is not required by your local codes, then no need to worry.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
