Thread: What do I need first after install of intex?
    Hello,
    We ended up buying an Intex 14'x42" pool, still in box. Wanted the 48" but this will be safer for the younger one for now....anyway.... Once we level the ground and install the pool, what chemicals do I need first? Want to have everything ready while we are filling it. Don't plan on buying a SWG at the moment.
    Thanks!!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: What do I need first after install of intex?
    Start with reading Pool School, linked in the upper right of every page here.
    Basically: bleach, stabilizer, and maybe muriatic acid.
    Do you have one of the recommended test kits? Really, that should be your first priority, so you know how much of what to add to you pool. Get one from http://TFtestkits.net . Best is the XL option, along with the speedstir. This is not an expense, it is an investment in keeping your pool safe and clean for you and your family.
    Aug 2010
    Dallas, TX
    4,052
    Specifically, there's an article in Pool School for opening a temporary pool.
    Casey's Avatar
    SW PA
    10,428
    Pool School is your friend flash828. Everything that you could ever want to know about pool chemistry and the items you will need are in Pool School.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Test kit, test kit, test kit....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mar 2014
    Thomson GA
    166
    Please post pictures as you install your pool.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
