Thread: CYA and water temp
    lee872's Avatar
    Central Massachusetts
    59
    CYA and water temp
    I opened pool a week ago and see a huge difference in opening earlier than I have in the past. I don't want to mess up a good start, so I'm looking for advice on CYA level. It measured 50 yesterday, and I'm aiming for 70 in gradual additions so I don't overshoot. Pool Calc said 1 gallon of liquid stabilizer to raise to 60; I added that yesterday. This morning CYA is about 52 -- hmmm. I'm wondering whether to stay on plan and keep adding until I get to 70, or should I be making adjustments for the cold water?
    I'm using bleach until I pull my salt level up. I'm getting salt today, and want to get it added today if possible because we have a rainy couple of days coming up and I want to get SWG going. So I guess part 2 of the question is should I start the SWG once the salt is up, or should I wait until CYA is at least 60?
    Levels:
    Water Temp 55, about 1/3 into deep end
    FC 5.5
    CC 0
    PH 7.5
    TA 70
    CH 190
    CYA 52
    P.S. Site upgrades are great!
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    38,394
    Re: CYA and water temp
    You can start the SWG as long as the water is warm enough. It is still early in the season, so the slightly lower CYA will not likely make much difference .... I would not be in a hurry to raise it up.
    The CYA test can be thrown off by testing with a cold water sample. It is best to allow the sample to warm up to room temperature before testing. That test is also sensitive to lighting. It should be read in full sunlight with your back to the sun and your body shading the view tube.
    Mar 2014
    Thomson GA
    166
    From the Aqua Trol Instruction manual "The Aqua Trol control will not produce chlorine at temperatures below 50 F. If your pool will be below this temperature for any length of time, you must chlorinate manually."
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
