Thread: Need help with air controlled panel
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Exclamation Need help with air controlled panel
    I have air controlled panel in my hot tub. I bought it used from a friend. When I brought it to my house and look under it and the remote sensing thermostat probe was just handing there. I cannot find where I suppose to plug it in.
    Here is a document from very similar control panel: Control Panel Info
    Is anyone here have a similar panel and can advise me what to do with that probe?
    Thank You
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: Need help with air controlled panel
    Bumping post to add it to today's activity stream. Hopefully someone will have suggestions for you.
    Love TFP? Become a
    TFP Supporter!
    Pysiek's Avatar
    Apr 2012
    419
    Nobody
    Knoxville, TN
    41
    There should be a thermowell for the probe to sit in, or it may attach to the heater in some way.
    The thermowells are typically located in a 90 elbow...
    Hot Springs certified service tech A
    APSP CST Certified
    CPO Certified
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by CPSScott View Post
    I will check. Thanks
