Thread: Filter Sand
    Apr 2014
    NM
    11
    Filter Sand
    I have a Sta-Rite Cristal-flo 24-inch sand filter. The manual says to use #20 Silica sand in the size range of .45 to .55mm, and a uniform coefficient less than 1.75.
    Okay, so I went to the two local big stores and found "Pool Filter Sand" with no data on the bags. One was Quikrete and their website didn't have much information except to say "Silica sand, sieve size 20-40, particle size .85 to .425mm".
    Should I use this sand? Or, should I start looking elsewhere for sand with good data markings?? I may not have many choices.
    Re: Filter Sand
    The Quikrete filter sand is just fine, as in nearly all sand labeled for use with pool filters. You do not want to use play sand, or sand with particles smaller than 0.4 mm.
