Thread: above ground pool questions
    Apr 2014
    Florida
    3
    Hello everyone. I'm brand new to pools and my wife and I would like to get either a 15' or 18' round pool. We are wanting a hard sided pool that's not going to break the bank but not fall apart. I was looking at a couple galvanized steel ones but I have concerns. I live in panama city fl and the air can get a bit salty. Will a pool like this hold up or will it rust like everything else metal?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: above ground pool questions
    Hi, welcome to TFP! If you are concerned about pre-mature rust through you may want to look into a pool with resin walls.
    Love TFP? Become a
    TFP Supporter!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    I've never seen an AGP with resin walls. I've seen aluminum.
    Jeff
    Apr 2014
    Florida
    3
    Thanks! I'm trying to stay away from aluminum because it seems to be a lot more expensive than the steel ones. Do you think galvanized steel will hold up well down here? Or is there something I could do to ensure it doesn't rust? Also, any recommendations on a pool? Thanks for the replies.
    Mar 2014
    Thomson GA
    166
    You could look for a pool that is saltwater rated. They usually have resin top plates, resin rails, resin bottom rails, steel sides and steel uprights. Wilbur has some with up to 60ys warranty (Pro-rated probably good for 10 - 20 yrs in salt). These pools are usually have a better coating on the steel parts. I purchased the Saltwater 8000 pool http://www.troublefreepool.com/threa...ing-27-AG-Pool and did a DIY install. Also consider the depth of the water you want AG pools come in 48", 52" and 54" depths. Some mfg. call them hybrid pools.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
