Results 1 to 7 of 7
Thread: Calling the experts for CYA Dial in....
    Jun 2013
    Newcastle, Oklahoma
    508
    Water temp is up to 73 so I retested CYA since last test was with very cold water.
    Level is 30ppm. first test was 35 ppm on mid 50s water temp.
    Pool is in full sun from sun rise to sun set
    Right now with no use, its consuming 2 ppm of FC per day. (Goal is 5, its at 3 ppm every morning at 830 - 900 am when I test and add 20 oz of bleach to bring up to 5 again) this has been consistant for two weeks straight. CC is zero every day. pH is 7.7 - 7.9 every day.
    I feel that since the range is 30-50, and im right there at the bottom of the spectrum, that I should add some stabilizer and get it up to 40 ppm.
    what do you guys think?
    leave it alone or up it to what?
    thanks.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I think a CYA level of 40 is good. Depends on what the FC loss is when you get further into the season with bather load and more direct sun. It's what I keep mine at and I get a lot of sun. Some pools demand a higher level. You can leave it where it is now and raise it later when the FC loss starts to increase. How much sun does the pool get ?
    Jeff
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: Calling the experts for CYA Dial in....
    100% sun across 100% of the pool for 100% of the day. yeah, 40 sounded good to me too.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Then I would think a level of 40 at least.
    Jeff
    Jun 2013
    Newcastle, Oklahoma
    508
    well, ill raise it tomorrow then.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If you raise it to 40 shoot for an FC level of 6-7. That will give you wiggle room so you don't fall below the min of 3.
    Jeff
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by pwrstrk View Post
    will do. thanks!
