Thread: Aquapure 1400 intermitent error code 120 general fault issue. Bad PIB or relay?
    Central Florida
    84
    I researched previous threads on this with no final solution.
    So here is my problem. System will general fault "service" 120 code on the non cell reversing portion but on the cell reversing cycle I do not get this fault and system runs fine. When the issue arises on the normal cycle the DCVolts on the cell posts run 36volts when on the cell reversing cycle no general fault errors the DCvolts are 32volts. I have seen that this could be a cell reverse relay gone bad, any thoughts on a fix? Do I replace the PIB back board or just install a new relay? Where is the relay and where can you get one? Is 32 DCvolts on the cell reversing cycle ok for I read that range should be 22-28?
    My temporary fix has been to turn everything off when on the normal cycle and general fault 120 pops up and turn back on to get the cell reversing cycle. If it is a bad cell wouldn't the fault code be on all the time? System is 2.75 years old.
    Thanks in advance
    18k free form IG w/spa (4 jets), Paramount in floor cleaning system, Starite system 3 filter, Jandy 2hp ePump, Sta-Rite SR400LP Maxi-therm propane heater, Jandy aquapure/apurem 1400 SWCG, Jandy automation PS4 w/PDA, IntelliBrite 120v 5-G LED pool & spa lights, 2" piping and (3)4x12 (5)4x10 Fafco Sunsaver Solar Panels.
    Central Florida
    84
    Re: Aquapure 1400 intermitent error code 120 general fault issue. Bad PIB or relay?
    Paging Mr. JasonLion and all the other TFP pros.. Seems my pool techs are stumped and want to replace the cell.
