Results 1 to 9 of 9
Thread: New style returns (not eyeballs) not doing the job
    Mar 2014
    Northeast Florida
    13
    I recently did a pool remodel and the PB installed a new style of return rather than the eyeball style. They don't seem to be adjustable to aim the debris (millions of small bugs) toward the skimmer. These little guys just float on by. When I put my hand in front of the return there seems to be lots of pressure like the eyeballs and there is action on the top of the water. The bugs that do manage to get to the skimmer just sit on top of it. Is this problem due to the returns or is the skimmer's suction bad? They did not replace the skimmer which worked fine with the old pool. Hopefully someone can give me some insight. I tried to upload a jpg image but cannot get it to load.
    38,346
    Re: New style returns (not eyeballs) not doing the job
    We are going to need pictures to know what type of return you have: How To Post Pictures
    Mar 2014
    Northeast Florida
    13
    http://www.troublefreepool.com/newth...newthread&f=11
    OK. Here is the image of the returns my PB installed. Is there any way to adjust these? How about get rid of them and replace them with the eyeball style. These seem to be nothing more than a hole in the wall that shoots out water.
    38,346
    That link does not show me anything: How To Post Pictures
    Mar 2014
    Northeast Florida
    13
    OK, hopefully this one works
    Mar 2014
    Northeast Florida
    13
    http://s28.photobucket.com/user/ssal...bfa5d.jpg.html
    OK, here is the photo of my return. Cannot figure out how to adjust them, if that is even possible. Assuming it is not possible, how to I remove these & install the common eyeball style? My PB doesn't seem to want to help since he has already been paid
    30,426
    Never seen those before. Too bad your PB won't stand behind his work. I would be harsh with him.
    That said, they should have a 2 slots 180 degress from each other in which you can insert a key. Or perhaps the two "ears" I see are made for that purpose.
    Where is the water level on the skimmers?
    Mar 2014
    Northeast Florida
    13
    Right now the water level is about an inch low; we are expecting a couple of inches of rain. This is the only level where any motion is seen in the pool. He actually did install a 3 way valve in front of the pump so that I can isolate the skimmer from the main drain. I need to figure out which way to move the valve to get more pull from the skimmer, I guess
    [URL=http://s28.photobucket.com/user/ssallyridexxx/media/IMG_2034_zpsee069f4f.jpg.html][IMG] <------Here is the water level
    I was very harsh with him yesterday and basically told him not to expect any referrals. You would not believe the experience I have had w/this guy. Where would I find a "key" like that to remove these returns? also, once I get them out will I be able to just screw in the standard eyeball?
    Last edited by dolllyxxx; 05-14-2014 at 03:13 PM. Reason: couldn't get photo to load
    38,346
    That does look like the 1.5" female threaded ports that I have as well. I think you can unscrew that retaining ring with the 2 tabs and the little plate with a hole in it should then come out. At that point you may be able to put an eyeball in and screw in another retaining ring. But, hard to tell from that picture.
    You got the first picture to show up, but the links are not right to automatically show on the last 2
