Thread: Pool full of Leaves and Green
    Apr 2014
    oklahoma
    2
    We have an Above ground 30 foot pool.. We have a ton of leaves in the pool and the pool bottom is very slimy. What will be the best way to turn the green pool to crystal clear?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool full of Leaves and Green
    Welcome to TFP!
    Start with Defeating Algae
    You'll want a pool leaf rake to get the leaves out to help speed the process along. It looks like this:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    Welcome!
    Assuming you want to do this as fast and cheaply as possible...
    1) Order a test kit. Recommendations TF100 with XL option. Speedstir makes it easier, faster, more accurate, and fun.
    2) Start scooping out debris with leaf net, as above.
    3) When arms and back get tired, go inside and start reading the pool school articles about algae and the SLAM process.
    4) When Pool school, makes you feel like read some of these for inspiration
    First Time Shocking with Bleach
    Pretty black pool
    A little encouragement for those with algae and new to BBB
    Frog Filled Green Swamp to Oasis---Work in Progress!!!
    Before and After Pool Pics
    Before and after!
    A final picture set of how well the BBB method works!
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    What Richard said!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Apr 2014
    oklahoma
    2
    Thanks for the help... looks like I will be very busy for a while cleaning!!!
