Thread: TF-100 Test Kit
    Mar 2014
    Mesquite, Texas
    29
    TF-100 Test Kit
    For the FC test, of the powdered reagent, how much is a "heaping" spoonful of the blue powder? The small jar seems to go real quick or am I using too much of a heaping helping?
    14K IG Aggregate Mini Pebble, 1 HP Hayward Single Speed Pump 120 GPM, 175 Sqft Cartridge Filter
    In-Line Chlorinator, 360 Polaris Black Max, Sheer Descent Water Feature. TF-100 Test Kit
    Build Date 2/1994; Remodel Date 4/2014; Original Owner, North Texas
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: TF-100 Test Kit
    It's probably not much more than you can hold between your finger and thumb.
    30,419
    Re: TF-100 Test Kit
    The instrcutions tell you the exact amount is not important and it isn't. All you are looking for is the soltuion to turn pink when you put the powder in. In 99.5% of the cases that is a somewhat rounded fill of the CUPPED portion of the dipper.
    How often are you testing?
    38,275
    Re: TF-100 Test Kit
    You can not use too much, but too little can skew the results. If the water starts with a nice pink, then you likely have used enough.
    I generally use one scoop when my FC is in normal ranges. Today when I was up around 20ppm I added one scoop which made a good pink, but added a bit more to be safe. And I certainly do not try to have a heap over the entire end of the spoon.
    Mar 2014
    Mesquite, Texas
    29
    Re: TF-100 Test Kit
    I'm testing every day. I'm new to this and have new plaster (March 27 fill date). My spoon is flat on both ends. Just ordered more so maybe I my new spoon with have a little cup
    SW Indiana
    9,199
    Re: TF-100 Test Kit
    Quote Originally Posted by doloskeeter View Post
    Look closely. One end has a small BB-sized cup in it.
