Thread: Muriatic Acid
    Mar 2014
    Mesquite, Texas
    29
    Muriatic Acid
    Is there a shelf life for muriatic acid similar to that of bleach?
    14K IG Aggregate Mini Pebble, 1 HP Hayward Single Speed Pump 120 GPM, 175 Sqft Cartridge Filter
    In-Line Chlorinator, 360 Polaris Black Max, Sheer Descent Water Feature. TF-100 Test Kit
    Build Date 2/1994; Remodel Date 4/2014; Original Owner, North Texas
    38,470
    Re: Muriatic Acid
    No...
    Re: Muriatic Acid
    Store your bleach in a cold dark place to make it last as long as possible. Store your muriatic acid some place with ventilation, because it out gasses and the fumes will rust metals. Don't store them together, because if they leak and mix, you'll get a chlorine cloud.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
