Thread: am i in trouble?
    am i in trouble?
    getting pool (33x4 agp w/ swg) ready for this year, I've been adding bleach (121 oz. 8.25%) to my pool. I haven't filled it up (below return jet) so i am not running the pump, filter, or swg. It was a solid green when I started because I couldn't keep my cover on, but that's another problem. So I added 8 bottles of bleach and 1 of muratic acid (ph above 8). two days later light green, cl at 0, and ph of 7. Added 10 bottles of bleach. two days later ph about 1 and ph at 7.2 so i added 4 bottles. last night I added another 4 bottles which I did not test before since it had been 4 days and bright sunny days in the upper 70's. tested it this morning and got an orange color on the test and ph at 7.8. I have new cl/ph titrate and tested it it two different locations. the pool doesn't have a cl smell to it that I can tell. cya levels are at 40. second cl test without ph test:
    on the brite sided, the pool is clear but just have to vacuum when I raise the water levels
    38,526
    Re: am i in trouble?
    You should be using a FAS-DPD chlorine test and not the OTO you are using now. The Orange just means your FC is "high".
    You really should not be doing all this without the pump running and should be following the SLAM process.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Doing what you have been doing may work to clear the pool, but it may also substantially shorten the life of your liner. This is why we teach testing and doing controlled addition of chemicals, not just semi blind shotgun approach.
    Ike
    Mar 2014
    Thomson GA
    166
    PH readings are not accurate at high FC.
    http://www.troublefreepool.com/threa...high-FC-levels
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Casey's Avatar
    SW PA
    10,461
    Why would you add so much bleach without filling the pool and running the pump?
