Thread: How to get my liner back blue.
    I had a serious algae problem. Pool water is now sparkling but I'm noticing the sides of my liner have been stained green. How can I get it back blue. Is there a special kind of brush I need or something I need to add to the water. 24 x 52 ag round.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: How to get my liner back blue.
    If you have recently completed the SLAM process (passed the three criteria to be done SLAMing - see red lines in my sig), then maintaining the FC slightly above target level should continue to lighten organic stains.
    Use a nylon brush on vinyl pool.
    You're done SLAMing when:
    Casey's Avatar
    SW PA
    10,448
    Keeping a slightly higher fc level should help clear the liner of organic staining. It will take some time though. Brush the pool daily with a nylon brush that butterfly suggested.
