Results 1 to 7 of 7
Thread: Bubbles from pool light
    So I fixed my pool light, or so I thought..... When I turn it on, bubbles start to come to the surface. Could this be because of heat and nothing else? I do not think there is an air leak on the seal because it has been submerged for 10 hours prior to this turn on. It ONLY happens when it is turned on. Any ideas?
    22,000gal IG, Lazy L, vinyl pool - 1.0 HP Pentair Whisterflo - DE filter - Blue Pearl Robotic cleaner - Glowbuoy - BBB only!
    Sep 2007
    Lafayette, Louisiana
    Re: Bubbles from pool light
    I would be very careful with this...
    Electricity breaks down water molecules into little fizzy streams of hydrogen and oxygen. That means the electricity might be making direct contact with the water you are swimming in, probably through the metal bezel around the light. Usually this would trip your GFI breaker with A/C current.
    Are you sure this only happens when the electricity is present? What was wrong with the light originally? How did you fix it? I really doubt that light can boil water, but maybe it's heating the air inside the light and forcing it out as it expands??? Do the bubbles persist forever?
    Just my 2c...
    Fortune favors the well prepared
    The build...
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    It only happens with power. It had a loose wire in the junction box so I fixed it and it worked. When I first turned it on, it was a steady stream of bubbles that turned into one every 15 seconds or so. I shut down after a few minutes so I do not know if they would eventually go away or if it is forever. But I also placed my hand on the ring and the surrounding water and I did not get zapped.
    Feb 2008
    Flower Mound, TX
    This reminds me of that experiment in junior high physical science where we applied an electric current to a piece of zinc under water to create pure hydrogen gas.
    This cannot be a good thing in a pool.
    As belldiver mentioned, your GFCI doesn't seem to be tripping the circuit and water is getting where it shouldn't be.
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    Oct 2007
    Philadelphia, PA
    Electrolyzing water requires a DC voltage. Assuming your light works off standard US power, it's 60 Hz AC. I don't see how this could electrolyze water into hydrogen and oxygen. (We can go into the chemistry, if you like.)
    What I suspect is happening is that there is a small leak into the fixture. As the light heats up the air inside is expanding and being forced out. When the light cools, water will be sucked in. This is a dangerous situation and must be address immediately.
    11x27 in ground, vinyl pool
    ~12,500 gal
    PAC FAB (Pentair) Pinnacle 3/4 hp pump
    Pentair 24 sq ft DE filter
    One skimmer, one return (no main drain)
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    I don't mean to say this may not be dangerous, but if ther was a lot ob bubbles at first and then just one evert 15 seconds, it's likely from trapped air being heated. Electricity splitting up the water would not have been producing more gas when first turned on than 15 minutes later.... I'd try to leave it on (nobody in pool) for a number of hours and see if it stops (once the light reaches maximum temperature).
    Am I right that behind the light is typically flooded with water? If so, there's no place for the air to be hiding except that it must be getting into the bulb-casing itself.
    My guess is that the back of the light was not put on well enough after the bulb was replaced. This hot gas beingn forced out will suck water in when the light cools. This is not a great thing to have... (I'd bet that you are starting to see some water begind the lens)
    my 2c also.
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    It was about half filled with water. The light fixture appears to be old so when I get some extra money, I am going to replace it. Until then, breaker is off and it will not be used. Thanks!
