Thread: Solar cover and reel recommendations and questions
    May 2013
    Fort Lauderdale, FL
    423
    I'm considering a solar cover for my pool to keep the temps up.
    1) It looks like it'll interfere with my polaris pool vac. Do I take the vac out when it's covered, or just not run it?
    2) I get a lot of tree debris- with a cover on, the skimmer isn't going to be able to get the stuff. And I'm guessing I can't skim the pool either with a net. How do you deal with leaves?
    3) Will my pool guard alarm work with a solar cover?
    4) Does the cover stay attached to the reel? So if my pool is 45' long, I need at least a 50 footer?
    5) Is it more danerous for kids and dog if they fall on a solar cover?
    My pool is a 45x12 with a love seat, step area, and it a small taper at the back, so it should be easy to have a reel at the end of the pool.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Solar cover and reel recommendations and questions
    Quote Originally Posted by zimm View Post
    5) Is it more dangerous for kids and dog if they fall on a solar cover?
    1) It probably won't interfere with your cleaner
    2) The leaves will land on the cover and fall off the end as you roll it up. I use my hose with a Bullseye nozzle and sweep the crud into the skimmer before I roll the cover off the pool.
    3) Yes
    4) It attaches with straps that are either screwed or velcroed onto the reel.
    5) Very much so. Falling onto a solar cover keeps you from swimming but can still put you under water. If you get under the cover, it is extremely difficult to raise it.
    May 2013
    Fort Lauderdale, FL
    423
    #5 is a deal killer for me. The way my house is set up, the dog always access to the pool. And if the kids can either unlatch the screen porch door, crawl out dog door, or even open the back door the yard, they have access to the pool. No easy/cheap way to secure the pool from the house without $5,000+ and 120' of safety fence in the deck.
