Results 1 to 16 of 16
Thread: AQ Trol RJ vs HP
    Apr 2014
    Arkansas
    15
    AQ Trol RJ vs HP
    I just ordered the AQ Trol RJ for my above ground pool being installed over the weekend. After reading a lot i noticed that the RJ is to direct return jet connection vs the HP to be connected inline. Can the RJ be connected inline? My pump is 30 feet away and i am hoping the RJ just have extra adapters that once removed works just as the HP. If anybody can help with this. Otherwise, i will know on Saturday when it arrives.
    thanks
    Re: AQ Trol RJ vs HP
    The RJ model comes with a slightly different set of connectors than the HP model, and is missing the flow switch which is required for inline usage. You can purchase the flow switch and connectors separately to convert an RJ into an HP.
    Apr 2014
    Arkansas
    15
    Ok thanks!. Order cancelled. What about the TL. what the difference?
    TL stands for twist-lock, and is independent of the RJ/HP choice. TL models are designed for use with pumps that have twist-lock plugs, while the non-TL models have standard plugs. Nearly everything is twist-lock these days, though older pumps are generally regular plugs. You should check your pump to see which kind of plug it has to be sure.
    Apr 2014
    Arkansas
    15
    Any experience with the Solaxx?
    Solaxx makes many different products. Which one are you thinking of?
    Apr 2014
    Arkansas
    15
    Solaxx SALRET20A Saltron Retro Retrofit Drop-in Salt Chlorine Generator with Timer for Pools, 20,000, amazon for $264. Easier than 500 for the Trol, good reviews.
    But looks like I may need to run an extension, which i hate to do.
    I don't recommend the Saltron Retro for pools over 10,000 gallons. it is usable but nowhere near as nice as the AquaTrol for smaller pools. Also, the cell doesn't last nearly as long as the one in the AquaTrol. If price is a major issue the Intex SWG is a better choice, though again it is no where near as nice as the AquaTol.
    Apr 2014
    Arkansas
    15
    i have 2 used intex units. was thinking if i could get by with them and push this for next year. but if the advantage is substantial may just do it right the first time. what do u think?
    Apr 2014
    Arkansas
    15
    How do I know if the pump is twist lock? how does it looks? Sorry for all the question but this website have been amazing. I am learning so much! My kids have bad eczema and regular pools make their eczema break out. With the SWCG they enjoy the summer and their skin actually improves substantially. This is a major investment in their fun but also in their health...
    A twist lock plug will look something like this one, very different from a normal plug.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Here is a photo I found online showing the common types of twist lock plug shapes along with a common household 15/20 amp 120V straight blade outlet. Most likely your pump will have an L5-15R or L5-20R, I suspect the former.
    Ike
    http://www.lockingpowercords.com/ima...%20ADAPTER.jpg
    Apr 2014
    Arkansas
    15
    OH! is the powercord? Mine looks just like a regular cord to a regular outlet. The outlet is a regular GFCI. Nothing fancy like that. I chose to put the pump next to the hose and run pvc underground to the pool rather tan running power to the pool and have an outlet sitting in the middle of the yard.
    Apr 2014
    Arkansas
    15
    So i assume the intex will work but need to run more hours while the aq trol will run great in shorter runs?
    Mar 2014
    Thomson GA
    166
    How large is your pool? The Intex is rated to produce Max 7 grams/hour of sanitizer. If your pool requires more sanitizer than this you will have to supplement the sanitizer with liquid chlorine.
    http://slink.intexdevelopment.com/b2...=163---R0-1307 EN.pdf
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Apr 2014
    Arkansas
    15
    Well, the AQ Trol HP is on the way!
    24' x 54" Grand Bahama Resin (14k gals) AG, 22" sand filter 1.5 hp pump, AQ Trol HP SWG, 04/26/14
