Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: Deep Cleaning a Sand Filter
    Smykowski's Avatar
    Sep 2011
    3,065
    This post will walk you through the anatomy of a sand filter, and then provide a video at the end for how to deep clean your sand filter. The filter used in the photos and videos is a Hayward S180T top mount sand filter. The images are of a similar filter. Obviously not all filters are configured in the same way, but this tutorial should get you well on your way.
    This post is intended to provide a more in-depth look at how the filter works. This post is NOT a substitute for understanding how to perform the basic functions of your filter in the daily operation of your pool. Please see the Pool School article for that information.
    Many new members with sand filters ask the question, "When should I change my sand?" The short answer is, usually never. Sand existed for millions of years before it ended up in your filter. A few years of working on your pool won't change it. While there are some rare circumstances where sand may need to be changed, in general a deep cleaning can do wonders for your filter's efficiency.
    Anatomy of a Filter
    Hayward S180T sand filter
    This is a picture of the filter. The Red circle is the "Intake" from the pump. The yellow circle is the "discharge" to the return. The orange circle is the waste port and the green circle is the sight glass.
    Not pictured is the band collar that secures the multiport to the filter body.
    This is the top view of the multiport with all of the settings. These six screws will disassemble the multiport, not separate the multiport from the filter body. Disassembly is necessary only to get to the spider gasket (where serviceable). To disassemble, remove all six phillips head screws. This will reveal the key, cover, and handle assembly, as well as the spider gasket. The spider gasket on this particular multiport is not a serviceable item.
    This is the multiport, removed from the filter, as viewed from the bottom. Small leaks from under the band collar are usually explained by the blue o-ring not being seated properly or being damaged (if tightening the band collar doesn't fix the leak). The bottom of the multiport will be seated on the standpipe in the next picture.
    This is a bird's eye view of the filter with the multiport removed. The pipe in the middle is the standpipe. Notice the thin layer of debris on top of the sand bed. As you will see later in the video, this layer will be removed, followed by a deep clean of the sand bed, before reassembling the filter.
    This is the lateral assembly removed from the filter. As seen in the second photo, the openings in the lateral fingers are each just thinner than a grain of sand. Always use extreme caution when working with the laterals to prevent damage. On this model, the laterals themselves do not screw in to the standpipe. The screws at the base of the assembly must be removed and the base separated to access each lateral. Other styles have each lateral finger threaded so that it can screw into the base of the assembly.
    Sand Filtration 101
    So how exactly does the water get clean? Remember those settings on the top of the multiport? Let's walk through them. Red arrows represent unfiltered water from the pool. Blue arrows represent clean filtered water. Green arrows represent dirty water.
    WARNING - When you turn the handle, the water is diverted in different directions based on the settings chosen. All changes must be made with the pump off! Put another way, never turn the multiport handle while the pump is running.
    Special thanks goes to Leebo for virtually cutting open then rebuilding my filter so you all can see the inside.
    FILTER - Filter is normal operation. On this setting, pool water enters the intake and is sprayed on top of the sand bed. It travels through the sand bed under pressure, where the sand filters out particulates. This now clean water enters the laterals at the bottom of the filter, travels up the standpipe to the multiport, and out the discharge where it returns to the pool.
    BACKWASH - As your filter cleans your pool, it becomes clogged with all of the particulate matter that was in the pool. Filter pressure will increase while flow decreases. Backwashing is necessary to clear out that sand and return the filter to normal flow. TFP recommends backwashing when filter pressure rises 20-25% above the clean pressure operation. In backwash mode, the flow is reversed from normal filter operation. Unfiltered pool water enters the intake and is directed down the standpipe, out the laterals and up through the sand bed. This action dislodges all of the dirt and particulate matter that has been trapped in the sand. This dirty water is sent out the waste port on the back of the multiport. Backwashing not only "washes" the sand, but also leads to resettling it in the next step, which is....
    RINSE - ....rinsing. Rinse is exactly the same as filter, except the filtered water is sent out the waste line instead of back into the pool. This step should always happen after backwashing for two reasons. First, any dirt and debris in the filter that did not get ejected during the backwash is now in suspension with the sand. Immediate filtering could put some of it in the pool. Second, the rinse helps resettle the sand bed for when the system is placed back in filter mode.
    RECIRCULATE - This mode bypasses the filter completely, as if it was removed from the plumbing loop. Unfiltered pool water enters the intake, skips the sand, and immediately goes out the discharge and back to the pool. The most practical use of this setting is during the early stages of a SLAM overnight, where mixing of the pool water is desired, but filtration would reduce flow too quickly.
    WASTE - In this mode, unfiltered pool water bypasses filtration and is ejected out the waste port. The most common uses for this mode would be "vacuuming to waste," or for draining the pool.
    The final settings on this multiport (and pictures don't really help) are as follows:
    WINTER - The multiport is intentionally placed between two settings, completely opening up the passageways. This setting is used while the filter is empty over winter.
    CLOSED - This turns the filter into a giant ball valve, cutting off and blocking water flow between intake and discharge.
    The Ultimate Deep Clean
    Backwashing is a maintenance action that should be taken during the swim season (or the SLAM process) when flow slows down and pressure rises. Sometimes a backwash just isn't good enough. This is when a deep clean is required.
    The deep cleaning should be done once a year at the beginning of your season to ensure the sand bed is settled properly. It will also help dislodge the debris from underneath the laterals at the very bottom of the filter. Finally, it is possible that filters get so dirty, packed and clumped together, small channels form in the sand. Water can take this route instead of through the sand, greatly reducing the cleaning power of the filter.
    Waterbear gave us the following instructions from this post:
    Open up the filter so the sand bed is exposed. Stick a garden hose into the sand and turn on the water. The sand should loosen up and all the dirt and gunk should float and overflow out of the filter. You might need to stir up the sand a bit. Keep this up until the water overflowing out of the filter is clean. If any sand is clumped together CAREFULLY break it up with something like a broom handle but BE VERY CAREFUL NOT TO DAMAGE THE LATERALS. You will be surprised at how much stuff this gets out of your filter than backwashing doesn't and I feel this 'deep cleaning' should be done yearly. This should take care of the channeling but if the sand has a lot of calcium deposits you might want to follow this up with an acidic sand filter cleaner from the pool store.
    **WARNING -- Before starting this process, be sure that the filter is isolated from the pool plumbing. I filmed this video at the very beginning of the swim season, and my plumbing was not hooked up yet. If the filter is still connected, turn off valves, disconnect plumbing, or do whatever you need to do to isolate your filter from the system. If you don't do this step, as you fill the filter with water, the junk and crud will fall into the standpipe and go right back into your pool.**
    The following videos show the deep cleaning.....
    https://youtu.be/MpNEBIIR5P4
    https://youtu.be/1wBhwYv_RKI
    aristobrat's Avatar
    Jul 2008
    Virginia Beach
    15
    Re: Deep Cleaning a Sand Filter
    Thanks for the videos, ... now I'm curious to see what the top layer of my filter looks like!
    7600 AGP, 200 lb/26" sand filter, 2-speed 2.5 HP pump
    (and two border collies that would swim in it 24x7 if allowed)
    Jul 2011
    Huntsville, AL
    96
    Thanks for this post. I'll be doing this today.
    18x36 IG Vinyl 23,000 gal, AO Smith 48Y 1hp pump, Jacuzzi Laser Sand Filter 250L, T104R, K2006, Polaris 280
    May 2014
    MA
    2
    We just did this today and couldn't believe the crud that came out! Thanks again!
    Thank you for your wonderful post - it was great! I did some youtube searching and watched some other articles, but I did have some questions that I felt may help other, newbie, users.
    I cleaned mine out today and it was so grouse what came out. I had what appears to be lumps of decayed material/poop sitting on the top and I had back filled/cleaned the media already for 10 minutes before my pump gave out. So, I definitely appreciate the guidance on deep cleaning.
    1. Are there issues if no sand comes out of the bottom of the drain port? I filled it three times and discharged, while I was cleaning, and still no sand.
    2. Is there a general distance/height that should exist between the sand bed and the collar? My filter had about 12" of empty space between the collar and the sand bed and while I saw/lost a lot of sand, in the past two years, in/on the pool floor I also vacuumed it back up.
    3. If you still see "junk" after 30 minutes, of constantly digging/cleaning in should you continue or consider replacement? I used to keep salt water aquariums and there are times where the sand is really gone and you are better off throwing it away and starting over.
    4. Do you recommend bleaching/cleaning the sand with one of those cleaner(s).
    5. I noticed a lot of bubbles forming even after 30 minutes of churning the sand, and the hose never reached the top/left the water, so is it fair to assume that we should continue cleaning/digging into the sand until no micro-bubbles are present?
    6. Going back to the salt water aquarium, filters tend to build up (good) bacteria that helps with breaking down organics. So, I would think that if you did it outside of a SLAM (or high chlorine scenario) it could have a negative impact on the chemistry of the pool and we should more aggressively monitor our water chemistry?
    I hope this helps other users and I appreciate any insight.
    Thanks in advance!
    Ben
    1) Either no sand is supposed to come out, or I am confused about your question.
    2) It varies from filter to filter. Often the correct height is mentioned in the manual.
    3) No, just rinse longer.
    4) No, water when rinsing and chlorine when in normal use is sufficient. There is a very rare exception when the filter sand is all a sticky gunky mess (almost never happens).
    5) Bubbles aren't a good indicator.
    6) Nothing lives in a pool filter, so there is nothing like this with a pool filter.
    Jan 2014
    Toronto, Canada
    17
    Is there a way to overflow the filter without pouring water all over the place? My filter is in a pool shed with wooden floors (and questionable electrical that I still need to sort out). I don't feel safe overflowing the filter onto the floor.
    adolson, no not really.
    Wonderful post! I just purchased a sand filter system and this definitely gave me a better understanding of how it works. Thanks so much.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by adolson View Post
    If you had a way to shut the hose off you could use a wet vac to suck the stuff up but you'd need to be able to shut off the water between emptying the vac.
    Solar Blanket, Well Water, Borax Added. 68
    Jun 2011
    San Antonio, TX
    6
    Just did this on my sand filter. Process worked great and yielded immediate performance increase in filtering. Thanks!!!
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    Thanks so much!!! I needed this!
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    Had my pool for 4 years, never did this, I'm excited / scared of what i'm about to find!!!
    35,000 gals. vinyl pool, SwimPure SWG, Hayward 1HP Pump, no heater
    Long Island, New York
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I know this was a month ago but I ran across someone who had a similar problem of not wanting all that stuff where the filter is and thought to use a small pond pump at the top to pump the water away from the filter.
    Seemed like a good idea and much easier than trying a shop vac.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Did mine today. Thought it wouldn't be too bad, since it's a 14" sand filter. Wrong! Didn't get the water running totally clear, it started to thunder in the distance, and I wanted to make sure I got it all put back together and back washed/rinsed before I headed in. I ended up cleaning it for over a half hour. The flow from the return was definitely higher. Filter two seasons old, never deep cleaned before.
    Found a place between the pump and filter that had stuff. Only got half of it out, but can try again some other time to remove it all.
    Thank you for posting this tutorial, it made it seem less intimidating!
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    I did mine yesterday. Ive had the this sand filter for 4 years and never had heard of this. It took almost an hour. It probably could've went longer because the more I stirred up the sand, the more stuff that came out. After seeing the gunk I saw, you can bet that I will be doing this every season from now on. Thanks for the great video!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Jul 2014
    Toledo, OH
    49
    I can't recall when the pool looked this good after the deep cleaning (and the SLAM). It's been nearly 15 years since I had the filter apart for anything, but I will do this more often now. Even though you have to take an S-200 apart to do it, it's worth it. Great tip and video.
    I've gone out to look for myself. If I return before I get back, have me wait for me.
    16x32x8 Fort Wayne Elite Polymer IG with vinyl liner and 8' acrylic end steps. Hayward S-200 sand filter with 220 VAC Super Pump and VariFlo valve. Installed in 1988.
    Jim
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Jamis, I feel your pain as I too split the filter in half to have easier access to the sand. Even with an electric drill and sockets it seems like you'll never get all the bolts out and same going back together !!
    Cig_arello's Avatar
    Apr 2014
    Eastern OH border town
    22
    I did mine today. WOW was I surprised. Two and a half hours to get it 95% clear running out of the top. I used an inflatable boat paddle to stir the sand and I moved the hose into different locations during the process. I doubt it has ever been done by the previous owners. I will deffinatly be doing this during opening every season from now on.
    18x36 IGVL 36,000 gallons 10.5' on the dive, 1 hp Hayward self priming super pump, 300 lbs sand filter w/ Hayward Vari-Flo valve
  20. Back To Top    #20
    Jul 2012
    South Carolina
    48
    Thanks for the videos. My husband did change the sand after 10 years of using a Hayward sand filter with the same sand. He had read that it loses it's coarseness and becomes ineffective. Our water became crystal clear after for a couple of weeks, only to become green again in the last couple of weeks. All chemistry is within the normal ranges. Is it possible he didn't get the sand settled in correctly? He is wondering if there is air somewhere because the Polaris Vaccuum is now floating too and he can't get it to run the bottom of the pool effectively. No debris in pool....just mustard algae...even with bleach at shock level which is why we think pool is not filtering correctly.
    15 K gallons
    Gunnite
    Centurion Pump/Hayward Sand Filter
    Polaris 360 Robot
