Results 1 to 11 of 11
Thread: Opened today .... issue
    May 2013
    Tulsa, OK
    83
    OK, we pulled the cover off the pool. In doing so we dumped all the lovely algae water and leaves into the remotely clear pool.
    Now I have to decide whether to drain it and eat the water cost or run the pump to clean it all out via the circulation system.
    Any thoughts on how low I can drain an AGP without worry.
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Opened today .... issue
    Was the water on top of the cover green and slimy, or just dirty?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Is there some reason you can"t just kill it with bleach and filter out the dead stuff? SLAM
    May 2013
    Tulsa, OK
    83
    Water was Green and Slimey,
    The cost of the bleach could out weigh the cost of the refill. Pool never got yucky last year so I didn't have to do any SLAMS just daily maint..
    Richard320's Avatar
    Jan 2010
    19,002
    Quote Originally Posted by heavyweight_4u View Post
    You're going to have to do a SLAM this year no matter what. You'll need to leave at least a foot of water in that pool so the liner doesn't wrinkle. My suggestion is to feed a garden hose or a vacuum hose into the pool slowly so it fills with water, cap the end, and haul it out to start a siphon.
    May 2013
    Tulsa, OK
    83
    I was prepared to SLAM after uncovering, but assuming draining more water and replacing some with clean would potentially lessen the length of SLAM needed, Its pretty swamp like right now after the dump.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If it was just the green water from the cover it may not take much to clear it.
    Jeff
    Casey's Avatar
    SW PA
    10,444
    The only way I'd drain an AGP is if I'm replacing the liner.
    I vote for scooping & SLAMing the pool.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Can you post a pic?
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mar 2014
    Thomson GA
    166
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Bleach and filter, you'll be back to blue in no time! The cover blew off my 12 x 28 Doughboy in a storm and the water was practically black and smelled like a fish tank. I have a pic in my "24 Egg Pool" thread.
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
