Results 1 to 8 of 8
Thread: Hayward Ultra- Replaced Almost Everything and still no luck!
    fox_and_hound's Avatar
    Jun 2013
    Sunny Florida
    79
    Hey guys, my Hayward is about 7 years old and usually new shoes and bearing change tunes it right up, but its been non-cooperative.
    It basically stalls in water, no movement. Sometimes I find it sort of on its side and not making full contact with floor. It doesnt clean at all.
    When I take it out of the water to inspect, the pods seem to get stuck when I move them even though I just replaced them.
    Here is what I have replaced:
    Pod Shoes
    Pods
    Wings
    Bearings
    Turbine
    A-Frame
    Here is some of the stuff I havent replaced that might be suspect:
    Gear Box (mine looks clean and all parts look good inside, but I could be wrong??)
    Top Gear Kit (seems harder than normal to turn, but Im not sure.)
    Upper body cone (again, seems harder to turn)
    Any suggestions on what I should try or how to diagnose which part should be replaced next??? I feel like I could buy a new one, but Im determined to get this sucker going!
    28k IG with Spa, hayward Super 2hp pump,
    120BTU Heater, Pentair PXC125 cartridge filter
    Love my Dogs, Maintain a Reef Tank, Foodie :)
    Jun 2013
    Sunny Florida
    79
    Re: Hayward Ultra- Replaced Almost Everything and still no luck!
    Im actually having the same problem with it that I had before I replaced all of the above parts. The turbine/pods are getting stuck. Its weird because all those parts are new. Anyone experience this before?
    Cig_arello's Avatar
    Apr 2014
    Eastern OH border town
    22
    I think we are in the same boat.
    http://www.troublefreepool.com/threa...ward-ultra-vac
    You still have the suction meter that it came with? If it is on its side it may not have enough hose length. The recommended is the length of the pool plus 2 additional hose lengths.
    18x36 IGVL 36,000 gallons 10.5' on the dive, 1 hp Hayward self priming super pump, 300 lbs sand filter w/ Hayward Vari-Flo valve
    Jun 2013
    Sunny Florida
    79
    I added extra hoses. Hate this thing!!! Still the turbine and pods are getting stuck. I will be putting in new gear box tonight (this is what Hayward told me to do), wish me luck! I will report back!
    Jun 2013
    Sunny Florida
    79
    Possible answer!!!!!!!!!!!!! Well, I am starting to think that my genuine hayward replacement a frame is mismanufactured. I also think its happened to other ppl too bc the same thing happebed with the a frame installed by my pool store. The chrome ends seem of a frame are sticking out a bit at the center aqua plastic overlay. Also the a frame wheels do not fit exactly against the plastic. It's almost like its a bit too big. If this true this is extremely disappointing and probably has affected a lot of people. I mean, I bought tons and tons of parts. Has this happened to anyone? I'll post a pic!
    Jun 2013
    Sunny Florida
    79
    Yep, two separate new A-Frames made the pods struggle and stop. They are genuine Hayward parts. I spent over $150 on all these parts. I put my old A frame in and glued a bearing and it no longer struggles, but not sure.
    Jun 2013
    Sunny Florida
    79
    Well I spoke too soon. It's moving so slow in pool, getting stuck on pool drain. I guess I might need a pool drain clip on to prevent that, but that was never an issue before.
    My filter PSI is 22 and filter is moderately clean (I hose it off when PSI is at 30), but I guess it could use a degreaser clean. Ive never used degreaser to clean filter.
    This is how I have my valves set, maybe something is set wrong, maybe not enough suction. I dont have the suction tester.
    Cig_arello's Avatar
    Apr 2014
    22
    I eventually got mine to work 95% of the time without getting stuck. I have to shut the main drain down to 25% open to get the full suction needed from the skimmer line open 100%. My filter runs @ 20psi after backwash. I did change the setting to the 3 spot too on the unit. I think this has helped it not to get stuck in the corners as much.
