Thread: Leaking Return Jet only when Skimmer is running
    Apr 2014
    Georgia
    1
    My pool recently started leaking. Dye showed the leak was at one of the return jets. What seems odd is that it only leaks when the skimmer runs. I shut the valve to the skimmer to isolate it and the jet does not leak. I can run the pump and the jets operate normally and do not leak as long as I leave the valve to the skimmer closed. A pool guy came over and he thinks the line is broken to the jet, but I would think the jet would leak all the time then?
    Any thoughts?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Leaking Return Jet only when Skimmer is running
    Welcome to TFP!
    I don't have any idea about your problem, but hopefully someone here will have a suggestion or two.
