Results 1 to 8 of 8
Thread: amo4lsu, New to TFP Forum
    Apr 2014
    Dallas, Texas
    5
    Can't thank y'all enough for the incredible, honest information and advice that is offered in this forum.
    Our pool was constructed Sept. 2011 and and for the first 2 3/4 years the pool water quality was great, but now we're beginning to experience a few of the issues that are the result of using the 'pucks and granules' method. Yesterday I ordered my TF-100 Test Kit and I'm 'all-in' on the TFPC method, which I should start this weekend.
    In my signature I state my pool uses an in-line Nature2 mineral sanitizer. Will this have a negative effect on the water quality when used in conjunction with the TFPC method? (I don't think it will, just wanted an expert opinion).
    Constructed Setp. 2011 / 14K gallon IG Plaster / Pentair FNS Plus 60 DE Filter / Pentair Inteliflo Variable Speed 3hp Pump / Pentair Legend Platinum Pool Cleaner / Nature2 Inline Mineral Sanitizer / Pentair Inline Chlorinator (no longer using except when away from the pool for extended time)
    38,235
    Re: amo4lsu, New to TFP Forum
    Welcome to TFP!!!
    With a quick search of the forum you will find that we NEVER recommend using a mineral system regardless of the methods you use to maintain adequate FC.
    If the mineral levels get too high in the pool you can get ugly staining which is very difficult to remove and can turn your hair green. Plus they refills are expensive and really provide no real benefit if adequate FC levels are maintained.
    Apr 2014
    Dallas, Texas
    5
    I kind of had that feeling, regarding the Nature2. I really haven't seen a benefit of having it in the system. It advertises a reduction in the use of chlorine, but when CYA levels climb it's rendered useless.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Indeed, these systems are not what they are cracked up to be, but Chlorine will never fail you. Looks like you are "seeing the light"
    Welcome to the forum.
    Essential Links:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Casey's Avatar
    SW PA
    10,418
    Welcome amo4lsu!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !!
    Jeff
    Apr 2014
    Dallas, Texas
    5
    Thanks for the welcome messages.
    TF-100 Test Kit arrived!
    My pool water is clear, but I've been fighting 'the Mustard' since the end of last season due to over-stabilization. Now I should be able to better gauge my CYA level and adjust to the ideal level. After that SLAM time.
