Thread: Please help me with liner questions
    Apr 2014
    Maryland
    9
    Hello, We moved into a house with a 27' above ground pool. It needs a liner. When I measure the height at the edge of wall, it is about 50". This pool had a drain in the center of the pool, which we will be removing. We've been told by the neighbors that they lost the pool water more than once in the winter when that drain, full of water froze. Anyhow, when we measured the height in the middle of the pool, it is roughly 54". So I am wondering if I need to buy a special expandable type liner, or if a regular liner would be ok.
    If anyone has recommendations of specific brands, and places to buy online, I would really appreciate it too!
    Mar 2014
    Thomson GA
    166
    Re: Please help me with liner questions
    What is the measurement fom the bottom rail to the top of the wall - not the top of the ledge?
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Apr 2014
    Maryland
    9
    What are you calling the bottom rail? Sorry! I measured the sand level to the top at the point where the liner would bend over to the outside. It's an overlap liner.
    Casey's Avatar
    SW PA
    10,438
    Measure the wall fro. The outside from the bottom track (wall sits in a track) to the top where the liner goes over the wall. It's either 48", 52", or54". If you have to move earth to see the bottom track, then do so!
    Nov 2011
    Moberly,MO
    1,010
    Don't worry about the center depth. Order for wall height
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
