Thread: Stenner pump for chlorine with a Pentair VS ?
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    So I've been reading thread after thread about using liquid chlorine instead of pucks & that's definitely the way I want to go (decided against a SWCG because of all the stone in pool)
    (I've been wondering what would be worse CYA problems or salt problems with the natural stone)
    But I'm trying to determine if having a VS pool pump will be problematic with a Stenner (like it seems to be with The Liquidator) ??
    Thanks
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    38,295
    Re: Stenner pump for chlorine with a Pentair VS ?
    No problem because the stenner pump injects the chlorine at a fixed rate, while the Liquidator relies on the suction from the pump which varies with rpm.
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Great !!
    I'm going to start ordering parts for a Stenner setup then .
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    This my Stenner and tank! I bought a Stenner tank as I want my unit to be stand alone next to my filter!
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    looks good
    you'll have to show an installed pic
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I sure will cnata, as I'm in Australia I won't be building my pool until September, coming into our spring.... We are freezing here at the moment... But I'm buying equipment over the next couple of months... Artificial turf goes down soon, it will be underneath my pool...
