Results 1 to 7 of 7
Thread: Pump pressure is too high
    Apr 2014
    San Antonio
    3
    Hello,
    I haven't been able to figure this out and the big box pool companies just give me maybes with no definite answer. The pressure of my pump is 30 psi when the filter is in, after the filter is cleaned. Without the filter in, it's still 15psi. When the filter is in, the pool water doesn't even move at all, leading to algae growth, and also, the chlorine tabs don't get enough water flow in to dissolve. It's awful, and I need it fixed, but I don't want to get screwed by a pool company in the process. Any help?
    30,432
    Re: Pump pressure is too high
    Welcome to the forum. It sounds like your filter has done exactly what you want it to do.....filter junk from your pool. Unfortunately, it is so clogged up with junk the water can no longer circulate. YOu likely need to thoroughly clean that filter or perhaps get a new one if it is hopelessly clogged.
    If you don't want to get screwed by a pool company, you will have to learn the things we teach here about Pool Water Chemistry.
    Proper balance of your pool water will preclude that junk (algae) growing in your pool to clog the filter in the first place.
    I would start with the ABC's of Pool water Chemistry in Pool School.
    Apr 2014
    San Antonio
    3
    [QUOTE=duraleigh;625894]Welcome to the forum. It sounds like your filter has done exactly what you want it to do.....filter junk from your pool. Unfortunately, it is so clogged up with junk the water can no longer circulate. YOu likely need to thoroughly clean that filter or perhaps get a new one if it is hopelessly clogged."
    But here's the problem...the second I put the filter in, it shoots right up to 30psi. No time for junk to accumulate.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Welcome to TFP!
    How old is that filter cart? Do you know if your pool ever had baquacil in it?
    To help us help you better, could you put your pool and equipment in your signature line?
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by soccrkeep1 View Post
    Are you talking about a new filter or the old one? Has the old one ever been cleaned? If so, how are you cleaning it?
    Apr 2014
    San Antonio
    3
    Quote Originally Posted by Smykowski View Post
    It's been used, but dipped at the pool place down the street. Made no difference. Worried I have a blockage somewhere.
    30,432
    If your psi jumps to 30 upon installation of your cartridge, then I would suspect you do have a blockage. What psi do you get if you run it without even putting the cartridge in?
