Thread: Jandy Valve Actuator Questions
    s9601694's Avatar
    Oct 2013
    Conroe, TX
    90
    I have a Jandy Valve Actuator hooked up to my iAqualink. Please see Attached drawing.
    Currently the settings are:
    1 - just regular returns
    2 - regular returns and gushers.
    I would like to have:
    3 - just gushers.
    I understand that the JVA isn't capable of doing this. its A or B, On or Off.. Is there a system (that works with iAqualink) that has a three way setting?
    if not (or too expensive/difficult) i think i will reprogram the JVA to:
    1 -Just returns
    2 - just gushers
    And have my variable speed pump go at high speed at valve setting 1 during the night and have the pump go on lower speed at valve setting 2 during "use-of-the-pool" hours.
    Thanks!
    See my POOL!
    Free form pool, 128 ft perimeter, max length 42ft, max width 38.5 ft, depth 3.5 - 8ft, Chilean Beach Gold Pearl Matrix, 13 ton moss rock waterfall, tanning ledge with 3 gushers, PV3 i, LED underwater lights, automatic water leveling system, 1424 sqft deck.
    38,521
    Re: Jandy Valve Actuator Questions
    I see no attached diagram. There are not actuators that stop at 3 places. You could change your plumbing such that you add a second actuator that would allow you to have the 3 options you desire.
    You only get two positions, but either or both of them can be anywhere in the valves range of motion. You adjust where the JVA stops using small cams inside the actuator.
    s9601694's Avatar
    Oct 2013
    Conroe, TX
    90
    Thanks for the answers! I forgot to attach the drawing but y'all get the picture!
    See my POOL!
