Thread: Paint for underwater PVC stem?
    Jan 2014
    Buckeye AZ
    807
    Beause our PB doesn't install telescoping fountains anymore...they put a 15" white PVC pipe and eyeball cap on the baja step instead. All the return jets are dark gray and the pebble is medium blue, so it sticks out horribly.
    Anybody use paint for PVC that is designed to be submersed? I'm thinking of asking boat repair guys....
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Re: Paint for underwater PVC stem?
    Krylon Fusion paint will work if you sand/scuff up the pipe beforehand, to improve adhesion, and then give it seven days to dry before submerging it.
