Thread: Question on pool pump GPH rating
    I need some quick help and I can't find the answer from the manufacturers website. I have a Waterway 2HP 2-speed pump that I am selling on eBay and someone wants to know the GPH. I have no idea and cannot find it from Waterway's site. The pump motor is actually made by A.O. Smith. Would anyone know the answer to this for me? Thanks in advance.
    24 x 52 Above Ground, 13,500 gallons, overlap liner.
    250 lb sand filter
    1.5 hp pump
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Question on pool pump GPH rating
    First, pool pumps are generally specified in GPM via the pump's head curve. So there is no single answer to his question. It depends on the plumbing head loss. However, you can point him to this site which has head curves for two different waterway pumps. Hopefully, one of them is similar to yours.
    Mark
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by pjb
    Sounds like you have an intex pool owner looking to upgrade.
    They certainly wouldn't want to upgrade to this it was way too much for my 24-ft AG with a 250-lb sand filter. I think you are right though because earlier she emailed me wanting to know if it came with a filter and how expensive were they to replace. I should have known then that she wasn't needing what I have and I told her that all I have is a pump. Oh well, I may just tell her I have no idea. I don't want to get tangled up with someone who isn't sure of what she needs.
    250 lb sand filter
    1.5 hp pump
    11,969
    I looked at my manual and it doesn't say. (mine is 1.5 HP)
