Results 1 to 10 of 10
Thread: Pool pump and filter location: Code?
    Apr 2014
    Long Island, NY
    20
    Does anybody know the NEC code regarding pool pump and filter location. My electrician said my pump had to be a minimum of 6' from my pool. I wanted to go 4'. Where would I be able to find that info?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool pump and filter location: Code?
    I don't believe there is any such requirement. It would be in NEC 680, though it is possible that your local government has implemented different requirements.
    680 specifically says that the receptacle for the pump wiring can be no closer than 5', but it doesn't specifiy the pump location.
    Is this an inground or on ground pool? For an inground, you want the pump as far from the pool as you can get it for noise reduction. Keeping it out of the splash zone can only make it last longer.
    Apr 2014
    Long Island, NY
    20
    Semi in-ground... Thanks... I may not have understood him correctly. So the receptacle he wants to put 6' away on a post. I will ask him again. Thanks for the quick response.
    The receptacle must be at least 6 feet away (or sometimes 10 feet, depending)(680-22(A)(1)). The pump it's self can be closer, though the cord connecting the pump to the receptacle can't be longer than 3 feet(680-22(A)(5)).
    Apr 2014
    Long Island, NY
    20
    Great.... thanks again.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Jason, do you know off hand if the "cord" can be longer by code if it is hard wired? I think my pump has a 5 or 6 ft flex whip
    Apr 2014
    Long Island, NY
    20
    FYI, my electrician has also stated that according to the most recent code revision all pool pumps must have a twist lock power cord.
    There aren't any obvious restrictions on flexible conduit lengths. The cord length limitation only applies to cords with plugs.
    The new rules require locking plugs, if you have a plug for the pump. But hardwiring is still allowed.
    By the by, temporary pools have different rules than what we have been taking about. Everything I wrote is about permanently installed pools. The line between permanent and temporary is kind of blurry, with different areas having different rules.
    Apr 2013
    Akron, NY
    40
    Just had my electric installed in the fall. Post had to be 6 ft from the wall of the pool, and cord to the filter had to be 3 ft or less with a twist lock. One circuit was the filter only with a hard wired timer - we also added an on off switch at the post for this circuit to be able to shut off the filter without unplugging. There also had to be an independent circuit with separate outlets for auxilirary items. All outlets needed to be in waterproof enclosures. And don't forget about bonding the pool with the copper wire around the perimeter.
    24 foot 54 inch AGP, 14.5k gallons, 1hp pump, 120 sq foot cartridge filter
    Apr 2014
    Long Island, NY
    20
    I did more research and that pretty much sums up what I found. Thanks Akron
