Thread: Nuvo H2O?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Nuvo H2O?
    I just saw part of an infomercial for NuvoH20. It claims to be a salt-free water softener system. It claims to do this using citric acid chelation.
    Would something like this help pool owners who have hard fill water and/or metal laden well water keep metal sequestered and the pH down?
    http://www.nuvoh2o.com/product-faqs
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Re: Nuvo H2O?
    No, that could work for homes but will not work for swimming pools. They do not remove calcium/metals from the water the way a normal water softener does. Instead, they use citric acid to essentially remove stains/scale as quickly as they form. The citric acid only lasts a few minutes. In a residential system where water is used as right away that can work, but in a swimming pool the citric acid will break down rather quickly and them you will get stains/scale just as normal.
