Thread: Final design today-looking for feedback
    Mar 2014
    Katy, TX
    17
    Today I am meeting with the builder to nail down our final design. Here is a picture I drew up after putting a hose in my yard to get a better feel for the space. Is there anything that I am missing?
    2nd, I know this is asked as nauseum...but what is a good depth for jumping? In the far curve, we are planning on having a deeper end for jumping feet first into. Is 6 feet deep enough? Or should we do 6.5 or 7? Trying to keep as much shallower area (3.5-4.5) to play. We have a 2 tiered tanning ledge (or a really big second step) to accommodate a chair for my special needs son...so that already takes up a good chunk of shallow area. Anyways, let me know of you guys have any suggestions!
    Mar 2014
    Katy, TX
    17
    Re: Final design today-looking for feedback
    Oh, and to give you an idea of size-from tanning bench side to back curve is 34' and the width is about 26' at the largest point. Only problem with this shape is no place to put a volleyball net
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I would go 7-8 feet for jumping or diving... I too have a special needs son who loves to swim... Good luck with the build you've got some nice ideas....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I assume this is jumping feet first from the side, not an elevated diving board or diving rock. If so I would think 7-8 ft is marginal, but would somewhat depend on the height of the person that is doing the jumping, etc.
    Oct 2013
    Phoenix area
    91
    Here in AZ, most play pools are 3/5/3', not really meant for diving. Jumping in at 5' is not an issue maybe if your over 6'6" in height. But if your encouraging kids to jump, most likely they will jump or flip head first. Deeper the better. 8' is deep, I think 8' is standard for residential low diving pool? No real answers just input...
    13,000 gallon IG
    PCC IG cleaning system
    Pentair equip.
    Attached spa
    Dire need for surface refinish!
