Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Question about an AGP
    Louisiana
    127
    Looking to purchase a new pool since the one i have now is starting to rust from i am guessing due to using a SWG. Top panels are gone and walls are showing some signs also. My current pool is also semi-inground. Looking around on the internet i came across a pool that i cannot find much info on and was wondering if anyone here knows anything about it rather good or bad. It is called the Medallion St. Croix freedom pool made by Medallion Pools and you can completely install inground.
    Also looking at the Wilbar Bermuda series and would like to know if anyone here has used this pool? Thanks in advance
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Question about an AGP
    They have some nice liners... They look like a pretty reputable company....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Louisiana
    127
    Thanks laceygirl. Guess no one has dealt with them, but have talked to them and seem very legit and honest about questions that i have asked. Been in business since 1960.
    TF 100 Kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I've noticed that Doughboy make some nice pools too... They've been around for 60 years...http://www.doughboy-pools.com/
    I wish I could get them in Australia.... Those and Radiant pools.... I'd love a Radiant pool but sadly both companies are not available in my country...
    Louisiana
    127
    Have not heard about Radiant.
    TF 100 Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Take a look at this thread. Picture of a Radiant pool.
    http://www.troublefreepool.com/showthread.php?t=72469
    Jeff
    Louisiana
    127
    They have a dealer 15 miles from me.
    TF 100 Kit
    Louisiana
    127
    wonder what a swg will do to it or warranty wise.
    TF 100 Kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Have a look at their website
    http://radiantpools.com/
    Mar 2014
    Thomson GA
    166
    CTGARDNER is installing a 24' Radiant pool. The two threads below herald his experiences.
    http://www.troublefreepool.com/threa...nstead-of-sand
    This is the thread about their pool failure
    http://www.troublefreepool.com/threa...AGP-warranties
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Apr 2014
    CT
    25
    I spoke with tech support at Radiant (my second call to them) and there's nothing in the warranty that precludes the use of a SWG. He said the only problems they've seen is when there has been small electrical current in the ground, which is something an electrician can test for.
    BTW, the pool we had that collapsed (the original King George) appears to be the same as the Wilbar Bermuda (Wilbar is the parent company of The Pool Factory, which made our King George). FWIW.
    Mar 2014
    Thomson GA
    166
    Interesting. I did not know that about The Pool Factory.
    Gerry
    Louisiana
    127
    Here is what I am thinking. Current pool is already semi inground so that work is mostly completed.
    Radiant Metric 27' with wavecrest pattern
    Walk in steps = really like this option
    Grand Tile for liner option
    Premium coping
    Foam pool coves
    Gorilla bottom
    TF 100 Kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Sounds very nice...
    Louisiana
    127
    Well I just Ordered all of the above. Should arrive in 10 days.
    TF 100 Kit
    Well dangg! I just received my pool from the pool factory...
    Louisiana
    127
    I am planning to build semi - inground, which is how my current pool is done. Ordered the walk in steps so will have to see how that goes since they are pretty much made for inground installations but said it can be done.
    TF 100 Kit
    Louisiana
    127
    well pool arrived yesterday and so for a disaster. Ordered premium coping and what i received was another coping called CP2 which is when you want to install completely inground and pour concrete around it. Called to get it worked out and company cannot sell me the premium coping and the one i received was considered what they call their premium coping, which will not work for my install. Now i have to pay to ship back and cannot get the actual premium coping because they are not allowed to sell. My local dealer will not sell also due to me not purchasing the pool from them. Now again i have to send back and then wait for the standard coping to come to me and will delay the install after i took off tomorrow to start.
    TF 100 Kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Oh wow... So sorry for your set back... That's weird about the coping.....
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,457
    Why wouldn't they tell you that from the get go? ugh.....
