Thread: Hey its cleaner than the Lake...
    Mar 2014
    United States
    5
    well im back. Been reading your posts and trying not to add a post where its not necessary. Alot of good information on here. I am stuck with a problem with my sand filter. Its an old, really old pool filter and can't read the name. I vacuumed the pool twice and keep seeing dirt coming back out of the ports after it goes through the filter. Yes i plan on changing the sand this weekend. I thought i hadn't backwashed properly but guessing sand it either too old or not enough. Just replacing all of it. My main question is has someone ever tried putting an inline filter cartridge along the vacuum hose to take out the fine dirt? I see them for sale but i don't think its hard to make. Any input? PCV and some stainless hardware should do the trick. Bulk pack of cartidge filters to go with.
    38,364
    Re: Hey its cleaner than the Lake...
    Sand hardly ever needs to be replaced. Could be a problem with laterals or the backwash valve.
    Mar 2014
    Thomson GA
    166
    The sand in the filter could be channeled.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Before you build the inline filter make sure the sand filter is ok. You could try deep cleaning and resetting the sandbed first and see if that corrects the problem. If you remove the sand check the laterals carefully and make sure there are no breaks or cracks. While you have the filter open inspect the spider gasket and lube it well with silicone pool lube. You can also try adding DE to the sand filter to catch more fine debris.
    Love TFP? Become a
    TFP Supporter!
