Hi I'm pretty new at this and I just got my 2005 taylor kit in. Everything looks good but my ta. Here are my readings
Cl 5
Salt 3500
Ph 7.4
Ta 140
Ch 240
Cya 60
Question is should I lower my ta even though my ph is spot on? How would u go about fixing the ta other than acid? I just added stabilizer (cya) a week ago because I added salt and had to add water for pool startup. I also added cal-hypo 2-3 weeks ago to shock. Since then my chlorine levels have been stable for a week at 5 with my pump running from 10am - 4pm and the chlorine generator set to 80 percent. Help needed here's my specs
18k gallon plaster pool salt water generator sand filter electric cover solar heat whisper flo pump
Cl 5
Salt 3500
Ph 7.4
Ta 140
Ch 240
Cya 60
