Thread: Stenner injection fitting vs check valve
    May 2013
    Dallas area
    85
    I see injection fittings on the stenner website for low pressure pumps but check valves for the high pressure pumps. What is the injection fitting? What is its function? Does it do the same thing as a check valve?
    Thank you,
    Anthony
    Dallas area, free form, quartz finish, flagstone, pentair cartridge, vs pump, swg
    Re: Stenner injection fitting vs check valve
    The injection fitting connects the hose coming from the Stenner to the main plumbing, injecting acid/chlorine/whatever into the main water flow. A check valve prevents water from flowing backwards, from the water pipe back into the Stenner.
    22,543
    As Jason said, the injection fitting is just an open threaded fitting that allows you to connect the tubing from the pump to the pool plumbing. Since it's basically just an open tube it doesn't have any back flow checking ability.
