Thread: Intellichlor IC40 low life, are the cells repalceable?
    It's 7 years old, do I have to buy the whole unit? Is the power supply the same IC20/40?
    Also the pool is 10K gallons, If I have to replace I think a IC20 would be plenty, thoughts?
    LB
    Sunny Sarasota Fl area
    10K Pool/SPA, Pentair equipment
    IntellifloXF
    Easytouch upgrade Panel
    Intelliclor IC-40
    Techno-Solis Solar Panels
    Re: Intellichlor IC40 low life, are the cells repalceable?
    The power supply is usually fine and only the cell wears out.
    Yes, the power supply is the same for the IC20 and IC40.
    Getting a larger cell usually saves you money in the long run, since it lasts twice as long and does not cost twice as much. An IC20 will usually be fine, but you will save money if you get an IC40. The larger cell also gives you more flexibility to run the pump for a shorter period of time.
    Thanks Jason
    Looks like it's time to pony up the $500
    LB
    IntellifloXF
    Intelliclor IC-40
