Results 1 to 7 of 7
Thread: intex pool leaking
    intex pool leaking
    Guys I have a small pin hole on the bottom of my intex 16ft ultra frame pool where it curves to bottom I need to get this fixed quick what can I do?!?!?
    38,262
    Re: intex pool leaking
    Use an underwater vinyl patch. I thought the Intex pools came with some.
    Jun 2013
    Newcastle, Oklahoma
    508
    if it is a small hole, a generous amount of PVC glue and a scrap piece of vinyl makes a decent patch as well. when I cut my intex last year to install the hayward skimmer... all went well until as I was finishing up, I did something incredibly stupid and bumped the sidewall with my exacto knife, puncturing a 1/4 inch gash in the liner!!!
    quickly I grabbed the pvc cement I had laying nearby, used my exacto knife to cut a 1 x 1 square out of the scrape vinyl I had from the hole for the skimmer I just cut, and put a good amound of PVC cement on it, slapped it on the outside of the pool and held pressure on it for about 5-7 minutes.
    hasnt leaked yet....
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    This leak is at the curve from sidewall to bottom
    38,262
    The patches are vinyl ... so they should be able to curve as well.
    I hust tried applying one of the patches the pool came with it say to use pvc cement well it did work just fell right off after a few mins of holding it there
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I didn't get any spare patches with my new Intex.... I was bummed.... I'll have to get one just to have on hand...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
