Results 1 to 7 of 7
Thread: My battle with white flakes from my SWG continues
    May 2012
    Elk Grove, CA
    60
    I know- there are lots of threads on this. I just took out my spacer cell and put my SWG back in a little over a week ago and I am already getting lots of white flakes. Can somebody point out whats wrong with my numbers here? According to my calculations, my CSI is just slightly positive (0.1), so I dont know why I'm having such a problem. I plan on lowering my TA a little bit to adjust the CSI down, but do you think that will help? I have an acid feeder so my Ph doesn't move a lot. I don't have any borates in the pool.
    One note- I think my CH regents might be bad- the R-0011L was very thick and took a while to mix in even with speed stir. That said, the number is about what I was expecting. I've ordered a bunch of new regents now so I will repeat once I get them.
    Ph: 7.5
    FC: 5.5
    CC: 0
    TA: 70
    CH: 575
    CYA: 50
    Salt: 3000
    Oh, my pool temperature is in the upper 60's to lower 70s.
    16k gal IG pool with SWG and DiamondBrite finish
    Pentair Intelliflo pump with 520 sq ft cartridge filter
    Re: My battle with white flakes from my SWG continues
    Your CH level is very high, so white flakes from the SWG is fairly common. You can eliminate the white flakes by adding borates or by lowering your CSI to around -0.3. Borates will help buffer conditions inside the SWG (where CSI is way higher) which should prevent the white flakes.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Another vote for borates...I can let my CH run all the way up to about 1000 before having problems.
    May 2012
    Elk Grove, CA
    60
    Update: I added borates, and haven't seen a single flake since. I'm happy!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Great news! Thanks for the update!
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    Thanks for following up and updating us. It's always nice to know that the chemistry is vindicated by real-world results. It was just a theoretical benefit until we've seen cases such as yours actually benefit from it.
    Casey's Avatar
    SW PA
    10,444
    AWESOME! Thanks for updating!!!
